CUCM 6.0 inbound call fail with h323 gateway
Answered Question
Jan 9th, 2009
Hi all,
i'm setting up a cisco 2821 as h323 voice gateway for a CUCM 6.X (i'md oing a migration from cucme to cucm).
This is the configuration h323 gateway config:
--- for inbound call---
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 69 pots
incoming called-number .T
direct-inward-dial
dial-peer voice 223 voip
preference 1
destination-pattern 223
voice-class h323 1
session target ipv4:10.1.10.10
dtmf-relay h245-alphanumeric
codec g711ulaw
ip 10.1.10.10 is the cucm ip address.
______________________________________
---for outbound call---
all is working fine!
So, if i try to call 223 number, CUCM reject call.
223 is a directory number registered on CUCM that is working fine for outbound call.
Any idea?
Correct Answer by Jaime Valencia about 8 years 4 months ago
make sure you're sending the call from the IP configured under CUCM
h323-gateway voip bind srcaddr ip_address
h323-gateway voip interface
CUCM only accepts calls from IPs he recognizes for H323
java
if this helps, please rate
Overall Rating: 3 (1 ratings)
Correct Answer
Jaime Valencia Fri, 01/09/2009 - 10:01
  • Cisco Employee,
  • Hall of Fame,
    2011
java
d.rocco Mon, 01/12/2009 - 05:35
This was helpful for resolve my issue!
h323 gateway configuration was right!
Thank you very much
Diego
kgroves42 Fri, 01/09/2009 - 11:46
Also make sure the Calling Search Space for the h323 gateway in CM can see the Partition where the DN 223 is in.
d.rocco Mon, 01/12/2009 - 01:14
I didn't configure any partition or calling search space. Is this mandatory?
Diego
STEFAN CHRISTEN Fri, 01/09/2009 - 15:37
Hi Diego
How many interfaces do you have on your H.323 gateway? If you don't configure the "h323-gateway voip bind srcaddr" command on the Interface with the IP configured in CUCM, the gateway will use the otugoing interface for the source IP.
Sometimes also a Reset on the H.323 Gateway Config on CUCM helps ;-)
Have you tried to "debug cch323 h225"?
Stefan
Hi stefan,
this is the debug:
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_call_setup_normal: SETUP_NTF_TIMER is not running. Continue processing.
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_IDLE state
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/check_qos_and_send_setup: Setup ccb 0x48D78A38
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/idle_fsSetup_hdlr: Setup ccb 0x48D78A38
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/copy_token_from_ccb: copy_token_from_ccb: Entered
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup:
generic_send_setup: is_overlap = 0, info_complete = 0
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: sending calling IE
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: ====== PI = 3
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: Send infoXCap=128, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: src address = 10.1.10.1; dest address = 10.1.10.10
gatewaypd#
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_CONN_LOST while at state H225_REQ_FS_SETUP
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_REQ_FS_SETUP
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_IDLE state
Diego
