Ciscoworks Netconfig
jmacchi
I keep getting the following message
Error occured while processing Possible Cause: Failed to Connect to JRM
I have tried to restart the Ciscoworks server, JRM and CTJRMserver but none have helped
I am trying to run a netconfig job
20 Replies 20
Joe Clarke
Please post the output of the pdshow command. What version of LMS is this? Was the hostname changed on this server recently?
LMS 2.6
Hostname was not changed recently
I have attached the pshow output
Please post the output of the command:
pdreg -l CTMJrmServer
The output of the DOS SET command, and the CTMJrmServer.log.
D:\CSCOpx\bin>pdreg -l CTMJrmServer
Process = CTMJrmServer
Path = D:\CSCOpx\bin\cwjava.exe
Flags = -cw D:\CSCOpx -cw:jre lib/jre -cp:p MDC/tomcat/webapps/rm
e/WEB-INF/classes,MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar,MDC/tomcat/webapps/
rme/WEB-INF/lib/log4j.jar com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServ
er i5981psp50
Startup = Started automatically at boot.
Dependencies = RMEDbMonitor jrm TomcatMonitor RMECSTMServer
You did not provide the SET output. Also, is this server integrated with ACS?
Yes the server is integrated with ACS
AdminEmail=jmacchi@sears.ca
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\tcomadmin\Application Data
CLIENTNAME=LL3LA689
ClusterLog=C:\WINDOWS\Cluster\cluster.log
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=I5981PSP50
ComSpec=C:\WINDOWS\system32\cmd.exe
CWMIBDIR=D:\CSCOpx\objects\share\mibs
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\tcomadmin
LM_LICENSE_FILE=D:\CSCOpx\objects\smarts\conf\trial.dat.DFM
LOGONSERVER=\\I5981PSP50
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=D:\CSCOpx\MDC\tomcat\bin;D:\CSCOpx\objects\smarts\lib;D:\CSCOpx\objects\smarts\bin;D:\CSCOpx\campus\bin;D:\CSCOpx\MDC\Apache;D:\CSCOpx\MDC\jre\bin;D:\CSCOpx\MDC\bin;D:\CSCOpx\lib\jre\bin\server;D:\CSCOpx\objects\db\win32;D:\CSCOpx\bin;C:\Program Files\Support Tools\;C:\Program Files\Windows Resource Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Intel\DMIX;C:\Program Files\IBM\Director\bin;;C:\PROGRA~1\F-Secure\Ssh;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0209
PROMPT=$P$G
SESSIONNAME=RDP-Tcp#4
SM_BROKER=i5981psp50:9002
SM_HOME=D:\CSCOpx\objects\smarts
SM_RULESET_PATH=D:\CSCOpx\objects\smarts\rules
SM_SITEMOD=D:\CSCOpx\objects\smarts\local;D:\CSCOpx\objects\smarts
SM_SNMP_BUG_COMPATIBLE=1
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Temp\2
TMP=C:\Temp\2
USERDOMAIN=I5981PSP50
USERNAME=tcomadmin
USERPROFILE=C:\Documents and Settings\tcomadmin
windir=C:\WINDOWS
Please post the NMSROOT/lib/classpath/jrmuser.properties file.
I have attached the file
Okay, there must be a problem with your System Identity User, lms26. How is this user defined in ACS?
it is set as omnipotent and SuperLMS under the CiscoWorks components (Ciscoview, RME etc)
why would that affect JRM?
The System Identity User is used for interprocess communication. If it is not defined properly, this type of error can occur. Please post the jrm.log.
the file is too large to attach (13 meg)
is there a statement i can look for in the file itself?
Please compress the file, and post it. It's all text, so it should compress well.
here is the jrm.log
