calling name not working on PRI
Jan 9th, 2009
Hello All:
I need some help
I have a PRI from Allstream using NI2 as switchtype connected to a Cisco
WS-SVC-CMM with IOS 12.4.(7h).
In the CM gateway settings, I checked box enabled for
Display IE Delivery and Redirecting Number IE Deliver.
Any suggestions?
Jaime Valencia Fri, 01/09/2009 - 10:22
  • Cisco Employee,
  • Hall of Fame,
    2011
have you confirmed you're receiving the calling name?? and on which IE??
java
if this helps, please rate
j.morand Fri, 01/09/2009 - 10:39
my problem are with outbound call. I want to send the calling name to my PSTN. The calling name with inbound call are OK.
Jaime Valencia Fri, 01/09/2009 - 11:11
  • Cisco Employee,
  • Hall of Fame,
    2011
OK, well still applies to make sure CUCM is sending the calling name. If you already have the name configured on every phone and the display checkboxes you should be sending the info.
a debug isdn q931 or a debug voip ccapi inout should show this.
java
j.morand Fri, 01/09/2009 - 11:20
I did !
So if I see "Display i = 'SIT'" I send the calling name to my PSTN and probably that the problem is from my PSTN ?
thanks.
Jan 9 19:14:50.465: ISDN Se1/5:23 Q931: TX -> SETUP pd = 8 callref = 0x0002
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A10B0201010201008003534954
Protocol Profile = Networking Extensions
0xA10B0201010201008003534954
Component = Invoke component
Invoke Id = 1
Operation = CallingName
Name presentation allowed
Name = SIT
Progress Ind i = 0x8083 - Origination address is non-ISDN
Display i = 'SIT'
Calling Party Number i = 0x0081, '4186563508'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4186562550'
Jan 9 19:14:50.509: ISDN Se1/5:23 Q931: RX <- STATUS pd = 8 callref = 0x8002
Cause i = 0x80E428 - Invalid information element contents
Call State i = 0x01
Jan 9 19:14:50.565: ISDN Se1/5:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8002
Jan 9 19:14:50.661: ISDN Se1/5:23 Q931: RX <- ALERTING pd = 8 callref = 0x8002
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jan 9 19:14:55.309: ISDN Se1/5:23 Q931: RX <- CONNECT pd = 8 callref = 0x8002
Jan 9 19:14:55.317: ISDN Se1/5:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0002
Jan 9 19:14:58.809: ISDN Se1/5:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8002
Cause i = 0x8090 - Normal call clearing
Jan 9 19:14:58.829: ISDN Se1/5:23 Q931: TX -> RELEASE pd = 8 callref = 0x0002
Jan 9 19:14:58.861: ISDN Se1/5:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8002
Nicholas Matthews Fri, 01/09/2009 - 11:40
  • Red, 2250 points or more
This:
Shows that your provider doesn't support this IE (Information Element).
I would ask your provider how they would like the calling number, or if they support it.
hth,
nick
Jaime Valencia Fri, 01/09/2009 - 11:43
  • Cisco Employee,
  • Hall of Fame,
    2011
you're definitely sending the calling name:
Name = SIT
Display i = 'SIT'
but telco is complaining of some IEs
Call State i = 0x01
probably it's the display IE with the name, i would call them and confirm they do support the calling name from your side. some telcos charge an extra fee for the service or some of them override the IEs or simply drop them. a call to the telco would clarify this.
try making calls to different numbers, i knew of some cases on which the issue was with the mobile company or the telco from the called party.
java
Nicholas Matthews Fri, 01/09/2009 - 11:15
More importantly - which protocol are you using? MGCP/H323?
