01-09-2009 12:19 PM - last edited on 03-25-2019 03:21 PM by ciscomoderator
What is the easiest way of putting an IP on my 4948s so that I can manage them over the network remotely. Here's my setup:
Switch A - 6509, vtp server, contains all vlan interfaces for all vlans.
Switch B - 4948, vtp client, trunked to switch A and Switch C, no configured vlan interfaces (with the exception of the default vlan 1 with no ip address)
Switch C - Cisco 4948, vtp client, trunked to switch A and B, same config as switch B.
I can easily manage my 6509 because all of my vlan interfaces are there and I can just telnet to one of them. Should I create a vlan interface on Switch B and C to do the same?
01-09-2009 12:23 PM
Randy
"Should I create a vlan interface on Switch B and C to do the same?"
Yes. Cisco recommendation is to use a dedicated vlan for managing devices ie. not vlan 1, not the native vlan and not any vlan that is used for servers/clients.
1) Create a vlan for management on the 6500.
2) Create a Layer 3 SVI interface on the 6500 for this vlan.
2) Create a L3 SVI for this vlan on each 4948 switch and then set the ip default-gateway on each 4948 switch to be the ip address on the 6500 L3 SVI of the management vlan.
Jon
01-09-2009 02:22 PM
Ok, so I created vlan 92 on my 6500 and created vlan interface 92 on the 6500 as well with an IP of 192.168.92.252 255.255.255.0
I then created vlan interface 92 on each 4948 switch giving switch b the ip 192.168.92.251 and switch c the ip 192.168.92.250. I then set the ip default-gateway on both switch b and c to 192.168.92.252. The results were:
- All switches can see one another
- The rest of my network can see 192.168.92.252 on the 6500 but cannot see 192.168.92.251 or 92.250.
- I can use 192.168.92.252 as my point of entry for access to switch b and c - but is this the expected result or should the rest of my devices on the network be able to see the IPs setup on switches B and C as well?
01-09-2009 02:40 PM
No, the rest of your network should be able to see this network as well.
Are you advertising 192.168.252.0/24 into your routing protocol so remote networks know how to get to it ?
Jon
01-09-2009 02:48 PM
well, my 6509 performs the route advertisment and if I do a show ip route, it defintely shows the 192.168.92.0/24 network being advertised to the rest of the network. (see below)
SwitchA-6509#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.26.1 to network 0.0.0.0
C 192.168.25.0/24 is directly connected, Vlan25
C 192.168.24.0/24 is directly connected, Vlan24
C 192.168.92.0/24 is directly connected, Vlan92
C 192.168.26.0/24 is directly connected, Vlan26
C 192.168.21.0/24 is directly connected, Vlan21
S 10.0.0.0/8 [1/0] via 192.168.26.1
C 192.168.23.0/24 is directly connected, Vlan23
C 192.168.22.0/24 is directly connected, Vlan22
S* 0.0.0.0/0 [1/0] via 192.168.26.1
01-09-2009 02:54 PM
Okay, so are all the remote networks connected to the 6500 switch ?
Can you
1) post output of "sh ip route" off one of the 4948 switches
2) From a remote address can you traceoute to 192.168.92.250 and 251 ?
What is the IP address you are using to try and connect from ?
Jon
