IPCCX 5.0 Database compatability
Answered Question
Jan 9th, 2009
Hi all,
I am new with IPCC Express 5.0 (CRS 5.0).
I need to know with which Database type CRS 5.0 is compatiblie with?
Is PostgreSQL supported by IPCCX 5.0 ? if not whic other DBs that can be supported?
Please i need urgent help
Thanks in advance.
Correct Answer by htluo about 8 years 6 months ago
It depends on which DB you're asking for.
For internal DB (for configuration, historical data, etc.), it supports MSDE 2000 and MS SQL 2000+SP4.
For external DB, it supports Oracle 10g, Sybase Adaptive Server 12, IBM DB2 8.2, MSSQL 2000/2005. Check compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Overall Rating: 5 (1 ratings)
Correct Answer
htluo Fri, 01/09/2009 - 19:05
  • Red, 2250 points or more
haouaswajih Sat, 01/10/2009 - 02:37
Thanks a lot, i was looking for external DB compatibility. This solved my issue.
Thanks again.
Best Regards.
