Load balancing between primary and secondary webserver
Jan 9th, 2009
Load balancing between primary and secondary web server and internet access for both the server required but i am getting only load balancing with them and they are not able to access internet through NAT and rotatory.both are directly connected to my ADSL internet router.PLe help me.
Giuseppe Larosa Sat, 01/10/2009 - 13:10
Hello Sujeet,
may you post a filtered version of your configuration in order to get better help ?
what is the output of
sh ip nat translations
Have you placed the servers in a DMZ interface ?
Hope to help
Giuseppe
sujitkr7cisco Tue, 01/13/2009 - 09:05
inside global inside outside local
114.143.x.x 172.16.10.24
there is no DMZ
from internet all ports are opening. how to block all except 80 for internet user and 25 for out side user.
