multicast question !!
Jan 9th, 2009
I have a multicast network running Anycast. I am trying to test the configuration using "igmp join-group x.x.x.x" on the two loopback interfaces of RP routers. MSDP is working fine and I am also getting ping response to group address from both routers when I send ping from another router in the domain.
The problem is that after getting successfull response ping packets starts dropping. The interface goes in Pruned state. It happens when I do failover testing by shutting interface on one RP router as well as I have seen this happening when both routers are up.
Is this anormal behaviour of "igmp joing-group" or does it indicate an issue with config? I have not found out any relevant document.
Would appreciate some help !!
Giuseppe Larosa Sat, 01/10/2009 - 02:25
Hello Fawad,
the usage of ip igmp join-group should be limited to functional tests with ping to multicast address group.
I would suggest you to setup a real multicast source and to have a real receiver.
One of the simplest way to do this is to use VLC from videolan that allows to send out a multicast stream on one PC and to receive it on another PC.
see
http://www.videolan.org/vlc/
Hope to help
Giuseppe
