Blocking selected International country codes
Jan 9th, 2009
We are currently using Cisco call manager 5.1.2 and Berbee version 5.1.1. and Unity. How can I can block international phone calls by country codes?
Thanks in advance.
Alex
Jaime Valencia Fri, 01/09/2009 - 14:11
create a route pattern 9011.countrycode! and choose "block this pattern", repeat for every country or summarize as possible
if not how you dial just adjust the logic to your dialing
java
if this helps, please rate
