Loadsharing per packet on ISR Routers?
Answered Question
Jan 9th, 2009
is loadsharing per packet supported on the ISR routers?
What commands can I use to influence Loadsharing on the ISR routers?
Thanks and best regards,
Peer
Correct Answer by Edison Ortiz about 8 years 6 months ago
Yes,
It's supported on ISR routers, please refer to the documentation:
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_i1.html#wp1012465
HTH,
__
Edison.
Please rate helpful posts
Overall Rating: 5 (1 ratings)
