CME 4.0 with CUE 3.1
Jan 9th, 2009
I had integrated CME with CUE and configured few mailboxes.When i press the message button its hiting the voice mail pilot number and able to login.But when i try to call the particular phone from internally/externally its not going to the voice mail,instead its giving a busy tone.
CFNA/CFB is enabled.
Advice.
pemelend Sat, 01/10/2009 - 11:11
hi
Try using under telephony service
call-forward pattern .T (or the patter you need to reach CUE)
If still fails, please upload sh run and debug voice ccapi inout.
thanks
do you have
Nicholas Matthews Sun, 01/18/2009 - 10:07
Hi John,
You have your SIP dial peer pointing to the wrong address. The unnumbered address isn't the correct address to be used, and you will want the .10 address.
In addition, you need the route pointing to the CUE module:
ip route 172.21.6.11 255.255.255.255 service-engine0/1
hth,
nick
binu.john Mon, 01/19/2009 - 21:55
my service module ip is 172.21.6.11 only
and i have already a ip route for,ip route 172.21.6.11 255.255.255.255 Service-Engine0/1.
my sip dial-peer is,
dial-peer voice 666 voip
destination-pattern 666
session protocol sipv2
session target ipv4:172.21.6.11
dtmf-relay sip-notify
codec g711ulaw
no vad
Ps note that the IOS is,
c2800nm-spservicesk9-mz.124-4.XC4.bin
Do i need to change the IOS?
pemelend Mon, 01/19/2009 - 22:57
I think your config looks fine, can you please upload debug voice ccapi inout?
Have you try to reboot the router?
Pedro
binu.john Mon, 01/19/2009 - 23:46
Thnx Pedro,
i reload the router and even the AIM-cue module too.
i done debug ccapi and codec its use is G7llulaw.
pemelend Mon, 01/19/2009 - 23:57
Hi, Please upload the debug so we can take a look and check which leg is disconnecting.
Txs
Pedro
Nicholas Matthews Tue, 01/20/2009 - 09:00
Check 'show ccn subsystem sip' on CUE. Make sure it has the correct default gateway. It's possible CUE is getting the SIP messages but sending the response somewhere else completely.
If you're using the SIP bind command, make sure it is the same address that CUE is using.
hth,
nick
binu.john Tue, 01/20/2009 - 23:17
Hi all,
I done everything,still the problem persist.
In telephony-service
call-forward pattern 6..
CUE# sh ccn subsystem sip
SIP Gateway: 172.21.6.10
SIP Port Number: 5060
DTMF Relay: sip-notify,sub-notify
MWI Notification: outcall
Transfer Mode: bye-also
SIP RFC Compliance: Pre-RFC3261
CUE#
Nicholas Matthews Sat, 01/10/2009 - 12:18
If you are using the CME as a gateway, you will need one of these two commands:
voice service voip
allow connections h323-to-sip
allow connections sip-to-sip
Also, make sure you're using G711 over your connection, and if not, you will need to configure transcoding.
You can also try these commands:
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
hth,
nick
