loadbalnce over L2 WAN
Jan 9th, 2009
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
hi guys
i have a customer with three sites over L2 WAN and each site has its own IP and static route between all sites for communication is configured
if one site only has new added link for this WAN netwrok how we can load blance those tow links other than useing tow static routes
i am awre about tow static routes that can do per packet or per destinationloadbalncing but this is for outbound traffic for the site that has tow links
is it possible to be done like virtulization
have one IP like VIP to to bundell those tow links?
also if for example used CSM or CSS how it can be configured
thanks
Giuseppe Larosa Sat, 01/10/2009 - 02:32
  • Hall of Fame,
    Founding Member
Hello Marwan,
Happy New Year
I'm not sure if I've understood your question.
The only way to use two WAN links as only one could be some form of L2 bundling
FR multilink FRF.16
I think you are using a FR service if so FRF.16 FR multilink gives you this option.
see
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_ml_fr_frf161_ps6441_TSD_Products_Configuration_Guide_Chapter.html
You will need to cooperate with FR provider to implement it.
FRF.15 and PPP multilink are instead suitable for end-to-end bundling but it shouldn't be your case (you say you added a second link on only one site)
Hope to help
Giuseppe
Marwan ALshawi Sat, 01/10/2009 - 04:40
hi Giuseppe
happy new year to u too
no it is not Fram relay it is shdsl
the router has to Fa link each one go to a s mall cisco shdsl router that used as bridge and the service is act as L2 not sure if it is MPLS or VPLS
anyway
the site with two links how i can bundell those tow links as one
with static route can be done for outbound only!!
PBR can do load share but this is manuel !!
thanks anyway
Giuseppe Larosa Sat, 01/10/2009 - 08:47
  • Hall of Fame,
    Founding Member
Hello Marwan,
no bundle option in your case I'm afraid; you need to use multiple static routes
Hope to help
Giuseppe
