Redistributing BGP into EIGRP
Jan 10th, 2009
Just a quick question as I feel I am banging my head against a brick wall here: is it actually possible to redistribute eBGP into EIGRP? I'm getting external BGP routes advertised across our MPLS, and I really need to stick them into EIGRP. If it is definitely possible I will post configs etc and explain in more detail!!!
Many thanks,
J
Overall Rating: 5 (1 ratings)
maahiraahi Sat, 01/10/2009 - 06:05
Redistribution of BGP in to EIGRP (IGP) is possible.
command is as below,
#router eigrp as#
#redistribute bgp as#
regards
jigsaw2026 Sat, 01/10/2009 - 06:23
Thank you, this is what I have already. Do you have an experience of it working?
Here's what I have:
router eigrp 100
redistribute static route-map redistribute-static-route-to-eigrp
redistribute bgp xxxxx route-map redistribute-bgp-route-to-eigrp
passive-interface default
no passive-interface Vlan21
no passive-interface GigabitEthernet5/0/1
network 192.168.22.0 0.0.0.7
network 192.168.22.8 0.0.0.7
distance eigrp 90 90
no auto-summary
router bgp xxxxx
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
network 192.168.2.40 mask 255.255.255.248
aggregate-address 10.3.0.0 255.255.0.0 as-set summary-only
redistribute static route-map redistribute-static-route-to-mpls
redistribute eigrp 100 route-map redistribute-eigrp-route-to-mpls
neighbor 192.168.2.46 remote-as xxxx
neighbor 192.168.2.46 description MLPS
neighbor 192.168.2.46 soft-reconfiguration inbound
neighbor 192.168.2.46 distribute-list 93 out
no auto-summary
route-map redistribute-bgp-route-to-eigrp permit 10
match ip address 92
Standard IP access list 92
20 permit 172.28.0.0 (2 matches)
30 permit 172.29.0.0 (2 matches)
40 permit 172.30.0.0 (2 matches)
sh ip route 172.28.0.0
Routing entry for 172.28.0.0/16
Known via "bgp "xxxxx", distance 20, metric 0
Tag xxxx, type external
Redistributing via eigrp 100
Last update from 192.168.2.46 1w3d ago
Routing Descriptor Blocks:
* 192.168.2.46, from 192.168.2.46, 1w3d ago
Route metric is 0, traffic share count is 1
AS Hops 2
And the same for the others. But these routes do not make it to the EIGRP topology table (there are no entries for these networks).
jigsaw2026 Sat, 01/10/2009 - 06:42
I just figured it out; I needed a default-metric configured.
Yay me! :)
Harold Ritter Sat, 01/10/2009 - 07:00
You need to configure a default-metric for routes being redistributed into Eigrp. The routes are otherwise not redistributed.
router eigrp 1
default-metric 10000 10 255 1 1500
or
match ip address 92
set metric 10000 10 255 1 1500
