pbogaerts Sat, 01/10/2009 - 13:53
Thanks pemelend, it was the bundle with ivr, do i need also too reinstall ivr ?
jconi Fri, 02/06/2009 - 06:40
I've exactly the same problem with 2 different NME-CUE modules.
Did you find the problem?
jp
Paolo Bevilacqua Fri, 02/06/2009 - 07:24
  • Hall of Fame,
    Founding Member
You should be able to reinstall these using the boothelper, you have to change boot options to boot from a tftp server, then installation would follow via ftp.
pbogaerts Fri, 02/06/2009 - 07:29
That is what I did, I reïnstalled usingb the boothelper, and after the problem was solved
