MPE installation problem
Jan 10th, 2009
Hi All,
We just purchased CID-MCS-7825-H3-RC1 and MPE 1.2 media from distributor. when I try to install MPE it says "hard drive is unknow".
what is the hard drive requirement for MPE installation? I made RAID 1 and tried to install, same error. then I marked RAID as bootable in BIOS configuration, still the same error.
any suggestion would be very appreciated.
thanks
Alex
Ginger Dillon Mon, 01/12/2009 - 09:18
  • Blue, 1500 points or more
Hi Alex -
I don't see that specific model listed in the release notes - http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace_express/1_2/english/release/notes/b_rn12.html#wp70126
The guide says 72 Gig drive space. The Cisco Unified MeetingPlace Express installer checks for the presence of the DVD-ROM drive, sufficient hard drive and memory sizes, and sufficient CPU type and speed. You may need to check with TAC on this hardware compatibility. I also enclosed the current HP hardware compatibility doc, although it references MPE 2.0 specifications - http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_solution_overview09186a0080107d79.html
Ginger
