Jan 10th, 2009
On a 2960...what is the command to show if portfast is enable on the ports?
starmantwo Sat, 01/10/2009 - 19:04
thanks for reply but i know how to put a port on portfast...i just wanted to know if there was any sh commands to display ports in portfast. Rather than doing a sh run...
lejoe.thomas Sat, 01/10/2009 - 19:12
Sorry about that, no its just the show run to verify.
show spanning tree interface | in PortFast
Mark Yeates Sat, 01/10/2009 - 19:31
Hi Lejoe,
I thought of that at first, but doing that will only show lines spanning-tree portfast and nothing more. It will not indicate which ports it is configured on.
Mark Yeates Sat, 01/10/2009 - 19:14
You can use the "show spanning-tree interface faX/X detail" command. It will show portfast is enabled or disabled. I don't know of a command that will quickly display all the ports of a switch that are configured for portfast.
