01-10-2009 09:25 PM - edited 03-11-2019 07:35 AM
HI ,
I have configured the username and Password when I used the password for ASDM,I can use only the privelge level- 2.
I can't configure anything.
messgae.
You are authorized to access only home and Monitoring Views.
How do to change privilege level for username?
Solved! Go to Solution.
01-10-2009 10:37 PM
username
e.i (lever 15 allows full EXEC mode access - as well as all ASDM features)
username joe password mypassword privilege 15
username cli syntax
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/uz.html#wp1568449
Additional reference for aaa authorization command
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/a1.html#wp1537175
01-10-2009 10:37 PM
username
username cli syntax
01-11-2009 02:38 AM
try this
username
01-11-2009 02:41 AM
username
01-12-2009 06:36 AM
For asdm leave the username blank and only provide the enable password.
you will log in as admin.
