process cpu statistics limit entry-percentage
Jan 11th, 2009
For the CPU statistics in Cat6500, what would a good percentage/size value for the entry in subject.
And how can I view the CPU statistics.
Roberto Salazar Sun, 01/11/2009 - 19:44
Not completely sure what you are asking but I'll take a shot.
6500 does all/most of it's packet switching in hardware with some exceptions. So, the cpu should be below ~20%+ (could be higher but should be no more than 50% at a sustained period) unless the RP is processing packet due to the exception I mentioned earlier.
Show proc cpu would show you the total cpu and the utilization of each process.
