CUCM: tomcat use most of the memory
Jan 11th, 2009
Hello!
CUCM 6.1(1) running on MCS7825H3-K9-CMA2.
The problem is:
admin:show process load memory
15:29:46 up 82 days, 6:07, 1 user, load average: 0.13, 0.16, 0.17
132 processes: 131 sleeping, 1 running, 0 zombie, 0 stopped
CPU states: cpu user nice system irq softirq iowait idle
total 0.4% 0.0% 0.0% 0.0% 0.9% 0.0% 98.5%
cpu00 0.0% 0.0% 0.0% 0.0% 0.9% 0.0% 99.0%
cpu01 0.9% 0.0% 0.0% 0.0% 0.9% 0.0% 98.0%
Mem: 2053864k av, 2034240k used, 19624k free, 0k shrd, 82080k buff
1244884k actv, 332464k in_d, 32208k in_c
Swap: 2048248k av, 987544k used, 1060704k free 835800k cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME CPU COMMAND
28642 tomcat 17 0 277M 254M 7924 S 0.4 12.6 611:20 0 tomcat
24467 ccmbase 15 0 133M 133M 67576 S 0.0 6.6 3:33 1 ccm
8149 informix 15 0 133M 132M 132M S 0.0 6.6 2842m 1 cmoninit
11119 ccmservi 22 0 147M 66M 4624 S 0.0 3.3 606:22 0 amc
11648 ccmservi 15 0 111M 57M 3600 S 0.0 2.8 65:48 1 rtmtreporter
11116 ccmservi 16 0 48944 38M 13872 S 0.0 1.9 1759m 1 RisDC
11194 ccmservi 16 0 170M 37M 3652 S 0.0 1.8 1376m 1 carschlr
6242 Administ 25 10 27576 26M 10064 S N 0.0 1.3 0:01 0 java
15291 ccmservi 15 0 35756 25M 10572 S 0.0 1.2 309:26 0 CTIManager
10594 licmgr 24 0 90524 24M 4708 S 0.0 1.1 61:59 0 CiscoLicenseM
admin:
What i can do to decrease using memory?
Should i increse the onboard memory from 2Gb to 4Gb?
Pls, advice me.
sunishnair Sun, 01/11/2009 - 06:23
Hi volkovvalery,
I also faced same problem. I restarted the CCM cluster. After that this reduce. This one bug in Call Manager. Or u can restart the tomcat service also.
I m not thinking u wanted to add more memory.
If u using the RTMT there also u can see this problem, there u can see Virtual Memory and swap memory also increased.
For this matter pls refer Cisco site and install latest service patches.
Sunish
volkovvalery Mon, 01/12/2009 - 00:32
Hi sunishnair, thanks for your reply.
I'm restarting the tomcat service (and ccm service) any times, but in a few days the same condition happening again.
Can i directly update cucm 6.1(1) to 6.1(2), and after this install 6.1(2)SU1a?
sunishnair Thu, 01/15/2009 - 22:59
can you please check with release notes for 6.1(2)after that you can upload the new service release for this particular problem.
Sunish
