01-11-2009 05:27 AM - edited 03-04-2019 03:25 AM
If I have a serial interface configured per below, is the hold-queue doing anything?
My understanding is hold-queue is a fifo function and by applying the QoS policy aren't I using CBWFQ in the interface?
policy-map P-QoS
class VOICE
priority 256
set dscp ef
class DATA-Priority
bandwidth 128
set dscp af31
class class-default
set dscp default
fair-queue
random-detect
map-class frame-relay P-class
frame-relay cir 1536000
service-policy output P-QoS
interface Serial0/1/0
bandwidth 1536
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type cisco
hold-queue 256 in
hold-queue 256 out
interface Serial0/1/0.400 point-to-point
ip address 1.2.1.54 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip flow egress
frame-relay interface-dlci 400 IETF
class P-class
crypto map P_Crypt
01-11-2009 12:43 PM
Hello Richard,
hold-queues are used for process-switched traffic like routing protocols hellos and updates.
QoS applies to user traffic
It shouldn't be a problem.
Hope to help
Giuseppe
01-12-2009 08:37 AM
Is there any reason to change these parameters from the default?
Also on the interface is:
"no fair-queue"
If I have a qos policy aren't I using CBWFQ?
How would this be affecting the policy applied to the sub-interface?
