DHCP on Aironet 1242AG
Jan 11th, 2009
I configured dhcp server on the Aironet 1242AG. There are two SSID's on the Aironet how can I bind this dhcp server to one of the SSID's so all the clients authenticating to this SSID will get their IP from the DHCP server that I configured on the Aironet?
Stephen Rodriguez Mon, 01/12/2009 - 08:33
  • Purple, 4500 points or more
so long as the DHCP scope matches the network you want the client to get DHCP from,it should work. When the client attempts to get DHCP it will do a subnet broadcast looking for the DHCP server, and the AP should respond.
challc2008 Mon, 01/12/2009 - 09:15
That is true but there are two SSID's and I want one SSID to be able to use one DHCP server and second SSID to use the DHCP server that is on the AP.
lcaruso Sat, 12/11/2010 - 06:41
  • Bronze, 100 points or more
Did you ever find a solution?
I'm looking for the same setup but have not found it.
Surendra BG Sat, 12/11/2010 - 07:18
  • Cisco Employee,
it will be great if you could start a new discussion for this issue..
Surendra
