CCNA prep material
Jan 11th, 2009
hi all,
a friend of mine is lending me his CBT Nuggets for CCNA by Jeremy Cioara....
he is also lending me cisco's Packet Tracer 5.0 software.
I do not have a budget right now for equipment, but i really want to learn this material and be proficient in it
Will this be enough? Also, since i'm using cbt and packet tracer, i do not have any labs....can someone suggest pratice labs? I know if you buy routersim's or boson's sim product it comes with a ton of labs
if i need to buy equipment, can i get away with buying one router? if so, what would be the best one?....in the first cbt nugget, Jeremy suggests the 851w
thanks so much
asad.rizvi Sun, 01/18/2009 - 23:12
Yeah 851w is best.
It comes with the recent IOS along with wireles :).
Try this bunch.
CCNA CBT Nuggests by Jeremy Cioara
Packet Tracer for simulation.
Wendell Odom Study Guide
For Labs,Try to :
- configure hostname for all devices
- secure the devices with user exec & privilige level encrypted password.
- configure domainname on routers.
- configure vty ports and let them use local authentication
- configure SSH version 2 on devices.
- DHCP Server on Routers
- Configure SDM Access
- Configure the Lab once with static routes & then with RIP.
- Configure Serial Links with PPP instead of HDLC
Try this first. I will update you about other tasks when its done.
Donot forget to vote :)
regards,
S. Asad Ali Rizvi
