CRS-1 support EoMPLS preferred tunnel selection ?
Jan 11th, 2009
Can anyone help me verify the CRS-1 support EoMpls Tunnel selection function ? or this function is only on the Cisco 12000 router ?
IOS-XR configuration guide 3.6 : have this function , I do not find any restriction.
I check IOS-XR 3.7 config guide, it say :
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.7/mpls/configuration/guide/gc37te.html#wp1325561
The following PBTS functions are supported only on the Cisco XR 12000 Series Router:
*L2VPN preferred path selection lets traffic be directed to a particular
TE tunnel.
So , I am not sure CRS-1 support it or not?
Thanks for your help.
Michael
Giuseppe Larosa Tue, 01/13/2009 - 03:01
  • Hall of Fame,
    Founding Member
Hello Michael,
it says:
•L2VPN preferred path selection lets traffic be directed to a particular TE tunnel.
•Both Interior Gateway Protocol (IGP) and Label Distribution Protocol (LDP) paths are used as the default path for all traffic that belongs to a class that is not configured on the TE tunnels.
•According to the quality-of-service (QoS) policy, tunnel selection is based on the outgoing experimental (EXP) value and the remarked EXP value.
•IPv6 traffic for both 6VPE and 6PE scenarios are supported.
My understanding is that the feature is not supported on CRS-1
Hope to help
Giuseppe
