E1R2 - is inter-register signaling configuration necessary?
Jan 11th, 2009
Hi all,
Would like to know if inter-register signaling (such as R2-compelled, R2-non-compelled) necessary for a E1R2 configuration?
I would like to integrate Cisco 2811 with NEC Neax 2000 using E1R2.
Thanks.
Nicholas Matthews Sun, 01/11/2009 - 20:14
It will be necessary, yes. There is information passed with the inter-register signaling that is required for call setup.
Here's a good document on E1 R2 theory:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800943c2.shtml#topic2
Also there's the little problem that the Cisco IOS CLI requires the inter-register signaling type when you define the ds0-group.
Router(config-controller)#ds0-group 1 timeslots 1-15 type r2-digital ?
dtmf DTMF tone signaling
r2-compelled R2 Compelled Register Signaling
r2-non-compelled R2 Non Compelled Register Signaling
r2-semi-compelled R2 Semi Compelled Register Signaling
Some interop documents:
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_troubleshooting_guide09186a0080142533.html
E1 R2 with NEC PBX using 3745:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/246672r2.pdf
hth,
nick
boonchin.ng Sun, 01/11/2009 - 22:56
Hi Nick,
Thanks for the quick reply. Hope you don't mind me to ask another question,
Do you have any experience if two-stage dialing is supported over E1 R2 interface?
Thanks.
