HWIC-4T1/E1 and VWIC2-2MFT-G703
Answered Question
Jan 11th, 2009
Can anybody help me in clarifying what is the difference between
VWIC2-2MFT-G703 and 4 Port clear channel Module (HWIC-4T1/E1
)in Cisco Routers.
Please provide the suitable solution
I pretty sure VWIC2-2MFT-G703 can be configured for maximum of 2 Channel-groups. How about 4 Port Clear channel card? Whether i can configure 31 independant channels (31 Links)
Correct Answer by paolo bevilacqua about 8 years 4 months ago
According to the datasheet, either framed or unframed operation is supported:
The modules support balanced and unbalanced E1 connectivity and conform to G.703 and G.704 standards for unframed and framed E1 modes.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/product_data_sheet0900aecd80710c77.html
Overall Rating: 5 (1 ratings)
hclisschennai Mon, 01/12/2009 - 23:03
Hi Sushil,
Thanks for your reply. I have surfed this link already before writing in this forum.
It is mentioned that 4 port clear channel supports only one channel.
1. is that mean i can configure only one channel group per port.
2. Whether it supports unframed also?
do you have any chance of worked with this port?
regards,
R.B.Kumar
hclisschennai Fri, 01/23/2009 - 10:07
Hi everybody,
Any clues..
VWIC2-2MFT-G703 and 4 Port clear channel Module (HWIC-4T1/E1 in Cisco Routers.
I am pretty sure VWIC2-2MFT-G703 can be configured for maximum of 2 Channel-groups. How about 4 Port Clear channel card? Whether i can configure 31 independant channels (31 Links)
hclisschennai Sun, 01/25/2009 - 10:31
Whether it is possible to create either framed (1984 Kbps-timeslot 1-31) or Unframed (2048 Kbps).
I know that it is not possible to create both in the same port. But I should be able to do it in atleast either
R.B.Kumar
Correct Answer
paolo bevilacqua Sun, 01/25/2009 - 11:36
  • Hall of Fame,
    Founding Member
