Forced Authentication Codes
Answered Question
Jan 11th, 2009
In call Manager, I knew that FAC can can be applied for the route patterns.But pl clarify me whether, FAC can be configured for a particular user or Ip phone.
The version used is 6.0
Karthik
Correct Answer by iftikharsyed_2 about 8 years 6 months ago
1. Define a new partition (SAY PT-FAC).
2. Define the route pattern (new one, you can define more then one RP with same pattern ) for which you want to implement FAC, enter FAC level for this pattern as well.
3. Associate PT-FAC to the crated pattern in step 2.
4. Create a new Calling Search Space and associate PT-FAC and all other required Partitions.
5. Assign CSS to the any phone you want to implement.
By doing so you will have two route patterns defined for same number format, one that requires FAC and other doesn't both seperated with PT and CSS.
Overall Rating: 5 (2 ratings)
iftikharsyed_2 Sun, 01/11/2009 - 22:45
You can do so by defining same route pattern assocated with a new partition then calling search space, Associate the new defined calling search space to intended user.
Iftikhar Ahmed
Correct Answer
iftikharsyed_2 Sun, 01/11/2009 - 23:03
karthiksr Sun, 01/11/2009 - 23:27
Thanks Syed.
Will try this and let you know.
Reg
Karthik
shzhang Thu, 01/29/2009 - 08:07
Hi Syed,
One more question for you. I have implemented FAC on Call manager and it works. I know user will hear two short "beep" before entering FAC. Is there anyway we can program call manager to make a anouancement something like "enter you password after beep"? I have most users complain that they don't know what to do after two beep. Thanks for your help.
Steve
iftikharsyed_2 Thu, 01/29/2009 - 21:21
Dear Steve, I didn't found any parameter for your request. What I have found is you can change the Text that is displayed on IP Phone when it prompts for Authorization code.
You can change the test from "Service parameter" by selecting your call manager server and then "Call Manager" service and changing "Forced Authorization Code Prompt Text"
Iftikhar Ahmed
shzhang Mon, 02/02/2009 - 10:27
Hi Iftikhar,
I can't find change "Forced Authorization Code Prompt Text" under "call manager" service in my call manager. My version is 4.1(3). You sure this feature is available in this version? BTW, do you know if Call Manager has cap on the number of FACs?
Thanks!
Steve
iftikharsyed_2 Mon, 02/02/2009 - 20:45
Hi Steve,
We have this option in call manager 6.0, I am sorry because i am not fimiliar with call manager 4.3.
we have more then 700 FACs configured in CUCM 6.0 without any issue.
Iftikhar Ahmed
Rob Huffman Tue, 02/03/2009 - 05:42
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Steve,
Just to add a note to the great tips from Iftikhar (+5 points Iftikhar)
This Text setting should be available in CCM 4.1(3)under;
Service> Service Parameters> Publisher IP Address> Service = Callmanager> Service Parameters Configuration> Clusterwide Parameters (Device - Phone)> Forced Authorization Code Prompt Text*
Here is another helpful guide;
Forced Authorization Codes (FAC) Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00807d11d4.shtml
There is no maximum number of FAC Codes that I have ever heard of, the max digits is 16 so there should be that number of permutations available.
Cheers!
Rob
shzhang Tue, 02/03/2009 - 08:37
Rob,
Why I don't have that option? My call manager is running 4.1(3)sr4d and ccm admin ver 4.1(0.11). Am I missing something on CCM?
Thanks!
Steve
Rob Huffman Tue, 02/03/2009 - 09:28
  • Hall of Fame,
    Founding Member
Hey Steve,
I just searched CCO and NetPro for any related info and found someone who couldn't find this setting on their 4.1(2) deployment either. I don't have a 4.1(x) box setup here so I can't look for this text setting. Have you checked the Enterprise Parameters?
Rob
sohaildxbfze Wed, 03/04/2009 - 00:49
thx for valuable comments rob,, i have 413 (sr5b) but this fac prompt is not there,, not even in enterprise parameters
lorcs Thu, 02/19/2009 - 10:22
Is there any scalable 3-party solution to provide 2000+ extension based FAC ?
tklawciscosp Thu, 03/12/2009 - 12:06
About Client Matter Codes:
I can do something like that: XXX[2-6]XXX
Something like a route pattern or a dial-peer configuration?
Thanks, Dante
Jaime Valencia Thu, 03/12/2009 - 12:16
  • Cisco Employee,
  • Hall of Fame,
    2011
no, only 0 thru 9 numeric values are accepted
java
if this helps, please rate
Jaime Valencia Thu, 03/12/2009 - 12:17
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Jaime Valencia Thu, 03/12/2009 - 16:39
  • Cisco Employee,
  • Hall of Fame,
    2011
No, unless you rewrite the whole code for how CUCM works. only numeric values are accepted
java
Jaime Valencia Mon, 03/16/2009 - 11:01
  • Cisco Employee,
  • Hall of Fame,
    2011
Enter a unique code of no more than 16 digits that the user will enter when placing a call.
theoretically 9999999999999999
java
rameshkrishna12 Sat, 05/02/2009 - 02:57
hi friend u can configure the FAC for a user(its not a correct and proper way)you can create different authorization code (ie. 123,124,125) by using same authorization level. and apply the authorization level in RP and give the different authorization code to users. as per the authorization code u can find out the CDR data.
Ramesh.k
[email protected]
