Group change in CiscoWorks
Jan 11th, 2009
I have run a report in ciscoworks to see which devices in my network do not have a certain command.
Now that i have found the devices which don't have the command (over 1000) how can i setup a task to apply the command to all the devices in that i found?
Joe Clarke Sun, 01/11/2009 - 22:54
You can do this using the Baseline Template feature under RME > Config Mgmt > Archive Mgmt. Basically, you'll create a template that has the command you want. Then, you'll run that template against your devices. You'll see all the devices which are not compliant, and you'll be given the option to do the deployment. Consult the context-sensitive online help for more details.
