Transcoding between two SIP trunks on 2811
Jan 12th, 2009
Hello all,
I have 2811 with 2xPVDM2-16. There are two SIP trunks, one should be g729 and the other g711. When I make a call from another side to the other with both trunks having g711 everything is fine, call goes through, you can talk etc. However when the codecs are different (transcoding should take place) I can hear the phone ringing but when B side picks up the phone, 2811 sends BYE to the B side. Sdspfarm is registered everything looks fine regarding the transcoders, still seems that transcoding cannot be done. I am using c2800nm-adventerprisek9-mz.124-15.T3.bin.
This seems to be trivial problem but I have already spent quite some time on it.
Here are some parts of running config:
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections sip to sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
voice class codec 2
codec preference 1 g729r8
codec preference 2 g711alaw
interface Loopback1
ip address 10.18.64.37 255.255.255.255
interface FastEthernet0/0
no ip address
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0.337
encapsulation dot1Q 337
ip address a.a.a.a 255.255.255.252
ip nat outside
service-policy input police-1M-in
service-policy output police-1M-out
interface FastEthernet0/0.338
encapsulation dot1Q 338
ip address 10.18.0.210 255.255.255.252
service-policy output voice
sccp local FastEthernet0/0.337
sccp ccm 10.18.0.210 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register transkodiranje
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 12
associate application SCCP
dial-peer voice 2000 voip
description outbound voip
destination-pattern .T
modem passthrough nse codec g711alaw redundancy
session protocol sipv2
session target ipv4:x.x.x.x
dtmf-relay h245-alphanumeric h245-signal
codec g711alaw
fax rate disable
fax protocol pass-through g711alaw
no vad
dial-peer voice 4000 voip
description inbound voip
no modem passthrough
incoming called-number 3851777595.
codec g711alaw
fax rate disable
no vad
dial-peer voice 3000 voip
description outbound pots
destination-pattern 3851777595.
session target ipv4:y.y.y.y
fax rate disable
dial-peer voice 5000 voip
incoming called-number .T
fax rate disable
no vad
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 12
sdspfarm tag 1 transkodiranje
load 7960-7940 P00308000400
max-ephones 2
max-dn 2
ip source-address 10.18.0.210 port 2000
timeouts interdigit 5
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-consult
best regards,
Goran Pilat
Nicholas Matthews Mon, 01/12/2009 - 07:12
  • Red, 2250 points or more
Hi Goran,
Try changing this:
to
sccp ccm 10.18.0.210 id 1 version 4.1
You'll need to disable sccp and remove the association first.
hth,
nick
goranpilat Wed, 01/14/2009 - 03:59
Hi Nick,
thanks for the reply. Unfortunately this didn't solve the issue. I have an IOS which should support universal transcoding. So the phone rings but immediatelly as the B side answers, BYE is sent by the router. If the transcoder is not registered (no sccp), the phone doesn't ring at all. So it seems that transcoder is not ignored in the call setup.
Any other advice?
best regards,
Goran Pilat
goranpilat Wed, 01/14/2009 - 04:24
Another thing, I noticed now that transcoding is done with no problems g711alaw -> g711ulaw (call goes through, I also see used channels with sh dspfarm all), but with g729 still doesn't work. Could it be that the codec from Cisco and Audio Codec modem are not compatible?
regards,
goran pilat
Nicholas Matthews Wed, 01/14/2009 - 06:15
You can check the codecs on your dspfarm profile, make sure you have the desired codecs there.
Additionally - check the SIP messaging and see who/why the call is disconnecting. It could be related to the annex of g729 they're attempting to use.
hth,
nick
goranpilat Fri, 01/16/2009 - 05:02
Hi Nick,
I just wanted to let you know that it is solved. When we put Asterisk instead of AudioCodes it worked right away (above config is fine). However I still find confusing the following. AudioCodes could only use g729A codec (off all the g729 variants) but Asterisk can use "pure" g729. But on dial-peer I can only put g729r8 and g729br8. To get things more confusing, on the transcoder you CAN set g729ar8, g729abr8 and g729r8. So I think with AudioCodes was something like this:
-I called the number
-the right dial-peer was hit
-codec on dial-peer matched the one supported on transcoding, the call establishment went on
-phone rings
-phone answers, sends that the codec it supports is not actually g729 but g729a (which can't be set on dial-peer)
-call is released
This is only my opinion,
Anyway thanks again, cheers
Goran Pilat
Nicholas Matthews Fri, 01/16/2009 - 05:26
Hi Goran,
Glad to see you figured this out. There are some hidden commands that change the way we handle some of the g729 annexes, so you may have been able to do some changes on the gateway.
-nick
