Backup and restore map with LMS Upgrade from 2.6 to 3.1
Jan 12th, 2009
Hello
Do you know if it is possible to save or export level2-map in topologic-view (mod Campus-manager) and to restore it in LMS3.1. My customer has more than 1000 device in his map.
Thanks in advance for your answer.
Michel Misonne
Joe Clarke Mon, 01/12/2009 - 08:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Assuming the LMS 3.1 server was created using the LMS 2.6 server's data, you can migrate the Campus maps. To do this, go to File > Upgrade Layout Views in Topology Services. More help is available by searching the Campus Manager online help for "upgrade view layouts".
