VoIP - two-stage dialing
Jan 12th, 2009
Hi all,
Just wondering is it possible to do two-stage dialing over a VoIP network? Meaning the remote router will be able to provide a secondary dial-tone, waiting for further digits before forward all digits to remote_PBX.
Local_Caller -> Local_Router -> Remote_Router -> E1 -> Remote_PBX -> Remote_Phone
Thanks.
Nicholas Matthews Mon, 01/12/2009 - 04:32
  • Red, 2250 points or more
Hi Boon,
This is done by toggling the direct-inward-dial on or off on the incoming pots dial peer.
Here's a doc:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801142f8.shtml
It says that CAS has direct-inward-dial enabled by default, so I'm not 100% sure this can be done. It may require the command 'no direct-inward-dial' on the pots dial peer.
For E1 PRI it can absolutely be done. Taking direct-inward-dial off of the dial peer gives the caller dial tone, and they can start dialing again.
hth,
nick
