RSTP diameter calculation
Jan 12th, 2009
Is this formula (found googling on the web) correct to calculate the diameter (number of hops) on an RSTP Layer2 ring ?
MaxAge=(4x hello)+(2x diameter) -2
by default maxage=20, hello=2, then
the diameter would be 8 ...
Is this correct for RSTP ?
Overall Rating: 3 (2 ratings)
Giuseppe Larosa Mon, 01/12/2009 - 05:59
  • Hall of Fame,
    Founding Member
Hello Gilberto,
a well designed and implemented RSTP network doesn't make use of maxage concept:
the more advanced BPDU handling should allow to make changes without waiting for max-age expiration:
on each point-to-point link a negotiation process named synchronizatio occurs and the two users will end to agree on port role and state.
Edit:
However, you can use the old rules for more safety
Hope to help
Giuseppe
grodoni Mon, 01/12/2009 - 06:10
Thanks Giuseppe.
Ok, but what happens on a ring with 20 switches or more when the root fails ? I saw an RSTP ring built with more than 20 non-Cisco industrial switches that has some troubles converging in case of failure of the root bridge.
There must be a "theoretical" and a "best of practice" limit in a RSTP ring topology....
Giuseppe Larosa Mon, 01/12/2009 - 13:20
  • Hall of Fame,
    Founding Member
Hello Gilberto,
if you have a ring topology and the root bridge fails : a new root bridge has to be elected.
With traditional 802.1D without max-age correct settings problem can arise.
With RSTP 802.1W this timer shouldn't play a role.
see
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml
the document says that Cisco has implemented a proprietary version of the synchronization process: a simplified version where only the root port is object to handshake.
Also a switch is authorized to accept inferior BPDUs when it loses its connection to the Root Bridge.
As I wrote in my first post you can choice an appropriate value for max-age and other timers that reflects the topology.
if the root bridge fails the ring is broken and all devices have to elect a new root bridge.
Hope to help
Giuseppe
grodoni Mon, 01/12/2009 - 23:31
Giuseppe,
thanks a lot for your answer,
I found the attache paper about the rstp convergence problems, which is also referenced in some other writings.
Giuseppe Larosa Wed, 01/14/2009 - 11:49
  • Hall of Fame,
    Founding Member
Hello Gilberto,
thanks for the link you have provided in your post.
Even if these are only simulations with a known network modeling tool they show the need for changing the max-age value.
Let us be practical increasing the max-age has no impact during normal and small failures.
Best Regards
Giuseppe
