01-12-2009 04:30 AM
Hi All,
Am I getting the following error on more than one port while changing the port speed from 2G to 4G on 9509.
Event:E_DEBUG, length:121, at 43883 usecs after Thu Jan 8 15:02:27 2009 [102] Ifindex (fc8/8)0x1387000, Err disabled (0x40290065) event (PI_FSM_EV_LCP_SET_PORT_CFG_RESP_RCVD)0xb8 due to Elsspc
Switch is working fine @2G. All other ports are set to 2G (Shared)
Any suggestion..?
Solved! Go to Solution.
01-12-2009 12:15 PM
Check the SFP installed in port 8/8 to be sure it is 4GB capable.
If it is, repost and we can dig deeper.
Hope this helps,
Mike
01-12-2009 12:15 PM
Hope this helps,
Mike
01-15-2009 10:05 AM
What model line card is it? What else do you have pulled into the port group and running at what speed?
Thank you.
