VPN client issue
Jan 12th, 2009
I am using PIX 7.0 and i have created a IPSEC Vpn and trying to connect the same from my VPN client 4.0
The group authentication is working fine but after for the user authorization is asking for username and password
Since we are not using any TACCAS or RADIUS is it possible to give user authorization as PIX local usrname and password
Vinoth
vinoth.kumar Mon, 01/12/2009 - 23:25
Thanks for your reply
I try to issue the command on my firewall but i dont have that command listed
(config)# vpngroup vpn3000 authe
(config)# vpngroup vpn3000 authentication-server ?
configure mode commands/options:
WORD The name of the IUA AAA server on the firewall headend
Please guide me
vinoth.kumar Tue, 01/13/2009 - 01:44
As requested i am sending the my config
PIX Version 7.0(1)
names
interface Ethernet0
description WAN_connectivity
nameif outside
security-level 0
ip address xxx.xx.2.3 255.255.255.224
interface Ethernet1
description Lan-connectivity
nameif inside
security-level 100
ip address 192.168.193.1 255.255.255.0
interface Ethernet2
description WEB_NATACCESS
nameif DMZ
security-level 80
ip address 10.108.1.3 255.255.255.0
access-list 101 extended permit ip 10.0.0.0 255.0.0.0 10.108.1.252 255.255.255.2
52
ip local pool RemoteVPNpool 10.108.1.253-10.108.1.254
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) xx.xxx.2.8 192.168.193.5 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 xx.xx.2.1 1
route inside 10.0.0.0 255.0.0.0 10.108.1.1 1
route DMZ 10.108.1.23 255.255.255.255 10.108.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy vpn3000 internal
group-policy vpn3000 attributes
user-authentication enable
username admin password eY/fQXw7Ure8Qrz7 encrypted
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp
crypto ipsec transform-set TCVPN-OLY esp-3des esp-none
crypto ipsec transform-set test-vpn esp-3des esp-none
crypto ipsec transform-set RVPN esp-3des esp-md5-hmac
crypto map mymap 10 set transform-set RVPN
crypto map mymap interface outside
isakmp identity address
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 11 authentication pre-share
isakmp policy 11 encryption 3des
isakmp policy 11 hash md5
isakmp policy 11 group 2
isakmp policy 11 lifetime 86400
telnet 10.0.0.0 255.0.0.0 DMZ
telnet 192.168.151.0 255.255.255.0 DMZ
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.193.5-192.168.193.200 inside
dhcpd dns 212.115.32.3 80.253.148.33
dhcpd lease 3000
dhcpd ping_timeout 50
dhcpd enable inside
tunnel-group vpn3000 type ipsec-ra
tunnel-group vpn3000 general-attributes
address-pool RemoteVPNpool
default-group-policy vpn3000
tunnel-group vpn3000 ipsec-attributes
pre-shared-key
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
Vinu
vinoth.kumar Tue, 01/13/2009 - 04:02
Thanks for your reply i entred the command after that i
debug crypto isakmp its shows some error
TCNEW-FW# Jan 13 04:41:02 [IKEv1]: QM IsRekeyed old sa not found by addr
Jan 13 04:41:02 [IKEv1]: QM FSM error (P2 struct &0x20c59a0, mess id 0x2dea489f)
Jan 13 04:41:02 [IKEv1]: Group = vpn3000, Username = admin, IP = xx.xx.37.82,
Removing peer from correlator table failed, no match!
vinoth.kumar Thu, 01/15/2009 - 03:53
Thanks for your information
now the iam able to login tthrough the VPN Client
I had a small question is it possible to recover VPN pre-share keys in PIX 6.3 (3) since we planned to put new firewall instead of existing one
