NTP problem on PIX 515E with 8.0(4)16
santipongv
I upgraded IOS on PIX 515E from ASA image 7.2(4) to PIX image 8.0(4)16. NTP statement disappeared. I tried to add NTP statement back, but got the following error messages:
Firewall(config)# ntp server 10.3.1.3
vPif_getVpif: bad vPifNum(0xffff) from B6F781 from 560BE7
UDP: ERROR - socket <unknown> 31488 in used
ERROR: Could not open udp/65535/123 for NTP
ERROR: failed to initialize NTP process
How can I resolve this problem? Thank you in advance.
7 Replies 7
m.sir
Level 7
Level 7
It looks you are hitting bug CSCsk75944
from
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCsk75944
ASA configuration of NTP - NTP process fails to initialise
Symptom:
Error when configuring NTP on ASA version 8.0(2).
# conf t
(config)# ntp server 10.12.6.119
vPif_getVpif: bad vPifNum(0xffff) from 87D5A11 from 8147AE8
UDP: ERROR - socket 31488 in used
(config)#
Conditions:
ASA 8.0(2)
Workaround:
Unknown
Does this apply to the PIX image 8.0(4)16?
did u try withjust ntp and ip address or did u also tried with
ntp server 10.x.x.x source inside/outside ect.
also source has sub command which u can check.
I did try all combinations and got the same error message.
Interestingly, I don't have NTP problem on another 515E with the same code (8.0(4)16) on it. Any thoughts?
Hmm thats not a good thing. Then it seems that it should not be the pix ios problem.
What about u r network any acl blocking port for NTP 123 ?
Any anything from the network side where the ntp server is configued is blocking this ip ?
that would be my only thoughts now
PIX is getting bad...
UDP 123 is allowed. Thank you for your inputs.
