Linksys SRW224P Dead - Only limited Console Access
Jan 12th, 2009
I have upgraded my SRW224P to Firmware SRW224P_Opcode_V2.0.2.2.bix using XModem and now it fails to boot.
I can interupt it via CTRL&U and delete the startup-config and then assign the SRW224P_Opcode_V2.0.2.2.bix as the Startup File as a Runtime but after each reset or reboot it fails to boot again.
Message:
[code]<ERR> Diagnostic Loading Fail - Try Runtime
Loading Runtime Image File : SRW224P_Opcode_V2.0.2.2.bix
Runtime 2.0.2.2[/code]
And when I interrupt via CTRL + U
[code]File Name S/Up Type Size Create Time
Factory_Default_Config.cfg 0 5 2771 24:00:17
SRW224P_Opcode_V2.0.2.2.bix 1 2 1850680 00:11:55
startup-config 1 5 2927 24:00:20
[X]modem Download [D]elete File [S]et Startup File
[C]hange Baudrate [E]rase Flash [Q]uit
Select>[/code]
Any Hints anybody ?
Steffen
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
