Route manipulation/route maps on ASA
Jan 12th, 2009
Hi.
A site is connected to internet through 2 different ISP.
The traffic flows from the LAN to internet across an ASA forwarding then the traffic to router 1. I wish now the traffic from network A to be forwarded to router 1 and traffic from network B to be forwarded to router 2.
I know this is accomplished with route maps, however i am not very familiar with them, especially on ASA.
Does anyone can enlight me?
Thank you anticipately
C
Collin Clark Mon, 01/12/2009 - 06:53
AFAIK route maps are not supported on an ASA. One way to do it would be to create two different NATs, one for Network A and one for Network Bin your ASA. In your router you could use route maps to send each network out different interfaces.
Hope that helps.
Carlo Zaina Mon, 01/12/2009 - 07:07
In config mode, the asa allows to configure route map:
ASA(config)# route-map INTERNET
ASA(config-route-map)# ?
Route Map configuration commands:
exit Exit from route-map configuration mode
help Interactive help for route-map subcommands
match Match values from routing table
no Negate a command
set Set values in destination routing protocol
I dont know if it works like on the routers.
Carlo Zaina Mon, 01/12/2009 - 07:31
It's the same chapter i read, however i am working with static routes, not with routes redistributions. It did not provide much help to me...
Furthermore, the ASA is not providing nat at the moment, since it is used for vpn L2L.
