Web access from outside getting through
Jan 12th, 2009
We have a ASA 5510 that is setup to Nat a single web cam to a public IP. There is a acl created to allow www access to this IP on the outside interface. When I do a show xlate I see the private IP natting to the public IP however from the outside we cannot view the webcam. From the inside we can web into the private IP address. I've removed and readded the acl and the nat statement with no luck. I've cleared the xlate table. I'm wondering what else I could look at.
Davy Ad Mon, 01/12/2009 - 07:20
Hi Jason,
I think it would be better ,if you could send or define you ACL configuration in clean way.It is hard to really know what could be the problem without this.
David
j.bourque Mon, 01/12/2009 - 07:27
access-list aclout extended permit tcp any host {public ip} eq www
static (inside,outside){publicip}{insideip}netmask 255.255.255.255
access-group aclout in interface outside
Davy Ad Mon, 01/12/2009 - 07:51
try this
access-group aclout in interface inside
DAK
