Jan 12th, 2009
I have a group of phones that when you press the CFWDALL button to fwd to another number it says the number can not be dialed. What could be the problem since all the other IP Phones let you use the cfwdall button with no problem.
rob.huffman Mon, 01/12/2009 - 07:01
Hi Bill,
The most likely cause for this type of issue is the CSS that is applied @ the Call Forward All level. Check out the CFWDALL CSS for these problem phones :)
Hope this helps!
