UCM 6.1(2) Voice Gateway Support
Jan 12th, 2009
I am currently working on a CCM V4.1(3) upgrade to UCM 6.1(3).
The UCM compatability Matrix no longer states which Voice gateways/versions are supported.
My CCM 4.1(3) has 4 x 2650XM MGCP controlled gateways. Can anybody confirm that they are supported with UCM 6.1(3).
thanks
Ian.
Jaime Valencia Mon, 01/12/2009 - 07:59
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, shows up as 26xx series
java
if this helps, please rate
iwearing Mon, 01/12/2009 - 10:47
Thanks for the update. Any idea on the recommeded Ver of IOS for the 2650XM.
thanks
Ian.
