"IP Gateway" returned to client is wrong with Cisco Anyconnect
Jan 12th, 2009
I am using Cisco Anyconnect 2.3.0185 and Asa 8.0(4).
IP address are assigned statically by ACS.
I specify IETF Rdaius Attibutes 9 (Framed-IP-Netmask) to return the correct mask ( like a ppp session).
But the IP Gateway returned to the client is not his own IP address and is another ip (i don't know how this other ip is returned ???) whereas it's working fine with Cisco VPN client Version 5 (<IP_Gateway> = <Static_IP>....
Do you have idea to correct the problem ?
Anonymous (not verified) Tue, 01/20/2009 - 06:31
Make sure that you have at least one RADIUS or TACACS+ AAA client configured in the Network Configuration section and that, in the Interface Configuration section, you have enabled the attributes you need to configure.
Note Some attributes are not customer-configurable in Cisco Secure ACS; instead, their values are set by Cisco Secure ACS.
Related URL:
