Username access
Jan 12th, 2009
I have been told that we need to shutdown all unused ports on all the switches. Since this is a lot of work, I have thought about giving this task to the helpdesk but I am afraid of them making a mistake; therefore, I would like to see if there is anyway of creating a username with certain access only to the interfaces and for them to be able to enable/disable them.
Thank you, Rafael.
John Blakley Mon, 01/12/2009 - 08:29
  • Purple, 4500 points or more
Rafael,
You'll want to look at privilege levels and roles. Definitely roles.
HTH,
John
ciscosrini369 Mon, 01/12/2009 - 09:22
i go with John, u can create roles, which will work fine
--srini
