speed setting?
Jan 12th, 2009
I have two 1310 bridges, point to point, aprox 2.5 miles, clear line of sight. During heavy fog the link goes down and does not come back up.
I noticed the speed setting was set to
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
(speeds above 11.0 never worked so that's the highest I set the speed to)
I also see you can set the speed to just plain
1.0 2.0 5.5 11.0
What's the difference between the basic-<speed> setting and the setting without the basic- prefix?
Stephen Rodriguez Mon, 01/12/2009 - 08:32
the "basic" speeds are the required speeds a client must support to be able to connect to the device. All others are considered "supported", meaning if we can negotiate to them, great! if not, then that's ok too.
