Adding extension to hunt group
Jan 12th, 2009
I have an extra extension i grabbed from another dept. I want to remove that number and add it to another hunt group so that when the main number calls this particular extension can pick it up. I already tried selecting what pick-up group it is in. However it does not work i cannot pickup any body's extension in that department.
Jaime Valencia Mon, 01/12/2009 - 10:42
  • Cisco Employee,
  • Hall of Fame,
    2011
version?
does it work if you dial to any other number in the pickup group directly?
have you added de bug info to enable pickup on hunt lists??
java
if this helps, please rate
Chris Alvarado Tue, 01/13/2009 - 07:18
The extension can not dial outside or anyone in the hunt group. Also nobody can dial the number.
Jaime Valencia Tue, 01/13/2009 - 07:30
  • Cisco Employee,
  • Hall of Fame,
    2011
1st thing to check is always CSS and partitions, make sure no unassigned DNs can be a match
java
