Anyone have a working config for FXO port to home Vonage box?
Jan 12th, 2009
I have purchased (waiting for delivery) of an FXO card to populate into my 2621XM router. My desire is to connect it to the analog port of my vonage box and integrate my Vonage "public" phone number with my Call Manager phone system.
Anyone have a working config that they would like to share?
Jeff
paolo bevilacqua Mon, 01/12/2009 - 09:23
  • Hall of Fame,
    Founding Member
Hi, Vonage FXO is not different from any other FXO so if you have one of these already just copy. Else you would need to specify if you want to use H.323/SIPor MGCP with this GW.
jeffrey.girard Mon, 01/12/2009 - 10:12
I dont have an FXO installed and plan on using H.323 GW from CallManager perspective
paolo bevilacqua Mon, 01/12/2009 - 10:42
  • Hall of Fame,
    Founding Member
In CM, configure an H323 GW with router's address. In router, under voice port configure "connection plar XXX opx" where XXX is the extension where your calls have to go. You will also need voip DP with CM address and destination-pattern XXX, and a pots DP with destinatition pattern like 9T. That's all.
