PAP2T - some devices cannot go off-hook to dial
Jan 12th, 2009
Not sure if this is the right place for Linksys VOIP hardware - though Cisco moved everything onto their site...
I have a PAP2T that seems to have trouble letting some analog devices dial out. Specifically, I tried it with a credit-card machine, and it seemed like the PAP2T would never go off-hook so it could dial. I saw no SIP traffic for any dialing. However, I immediately plugged the same FXS port into a fax machine, and that fax machine was able to dial out fine.
jbayuka Tue, 01/20/2009 - 08:22
Before you set up port forwarding on your router, change two of the Phone Adapter's settings using its Interactive Voice Response Menu. First, disable its DHCP feature, then assign a static IP address to the Phone Adapter.
