Presence integration with Sametime
Jan 12th, 2009
I have a CUCM v6.1.2 & CUP 6.0 that I want to integrate with Sametime v7.5.1. The integration I need to implement is click to call & presence functionality. I have successfully configured the click to call functionality, but I am having some issues with the presence integration. The error message I see in the sametime client is "Login failed". It seems like the presence server can not authenticate the user credentials.
It's not clear to me where users are provisioned at Presence server. I'm trying to authenticate using username/password configured in CUCM.
Is this correct or do I need to integrate with an LDAP server?
Thank you in advance.
epekou Mon, 01/12/2009 - 12:01
Thanks for your reply Michael. I use the same username/password for both plugin & CUPS user page. I can login to the user page but not through sametime. Any idea why?
htluo Mon, 01/12/2009 - 12:36
  • Red, 2250 points or more
If that's the case, it could due to "Digest Credential" was not configured on CUCM > User Management > End User page.
You may bypass Digest Credential check by going to CUPS Admin > Cisco Unified Presence > Proxy Server > Incoming ACL. Create a 'all' ACL there.
Michael
epekou Wed, 01/14/2009 - 01:40
Hi Michael,
I have added the access lists as you suggested and now the user can login to the presence server. But still the client can not "see" the presence server.
In the "Cisco Unified Server (Presence)" section I see the following:
Server:
Port: 5060
Domain: nbg.gr
Status: Error - connection timeout
Any idea why the "server" field is empty?
Evi
htluo Wed, 01/14/2009 - 10:09
1) On "Troubleshooting" tab,"Enable detailed logging"
2) Exit and re-launch Sametime
3) Go to "Troubelshoooting" tab. Create Problem report.
4) Attach problem report here. We'll take a look.
Michael
htluo Thu, 01/15/2009 - 11:13
Per the logs, ST plug-in received presence info. But it failed to map that presence into to ST user.
In Domino directory, the user ID part of the email, does it match the user ID on CUCM?
htluo Thu, 01/15/2009 - 15:18
CUPS/CUCM's user IDs are case sensitive. do they match exactly with ST?
htluo Thu, 01/15/2009 - 19:04
Ok, took a 2nd look at the logs. It looks like the initial configuration of your CUPS has not completed yet:
You haven't configured the Proxy Domain for your CUPS server. Please go to CUPS Admin > System > Service Parameters > Cisco UP SIP Proxy
Best practices:
1) Always run troubleshooter on CUPS to rule out the "basic errors".
2) Always test with CUPC before you deploying ST plugin. Because ST plugin is just a "mini-CUPC"
Michael
