http inspect limit ??
Jan 12th, 2009
any one knows which is the limit to filter URI by regex instances ??, the idea is filter content by match the http trafic and regex statements, this is going to be in a asa 5510
vmoopeung Tue, 01/20/2009 - 09:40
  • Bronze, 100 points or more
To set the rules by which the Content Engine filters HTTP, HTTPS, and RTSP traffic, use the rule global configuration command. To disable individual options, use the no form of this command.
The general rule command is as follows:
rule {action action-type pattern-list list_num [protocol {all | protocol-type}] | enable | pattern-list list_num pattern-type}
m.sonnlef Wed, 01/21/2009 - 09:41
the configuration is already done, the question was mostly for the workload in the apliance, but this equipment is already in production, and working fine whith the filter over 60 pc's surfing the web, thank any way.
