01-12-2009 02:33 PM - edited 07-03-2021 04:58 PM
is it possible to works wireless 802.1x in WPA2/AES and auth PEAP-MSCHAP-V2 without use of certificat ?
Michel
01-12-2009 03:37 PM
No. You need a server-side certificate to use PEAP.
Good Luck
Scott
01-13-2009 12:37 AM
Yes, just un-check the "Validate Server certificate" under Protected EAP Settings
01-13-2009 01:16 AM
Hi Michel,
Sorry, my reply to your post is wrong. Even you don't try to validate your server certificate, you must have one because this is a fundamental part of this method.
01-13-2009 04:57 AM
You just need to have a certificate on the RADIUS-server to start PEAP. It's easy to generate a self-sign certificate, using Open-SSL.
The clients don't need any certifcate and don't need to know the server certifcate.
Good luck
Johan
01-13-2009 09:30 AM
it's ok with just a self signed certificat on server.
thanks,
Michel
