BGP and OSPF issue
Jan 12th, 2009
Is there anything that specifically needs to be stated in IOS to enable BGP and OSPF to run together? I have attached a simple net. diag. I can not get OSPF to establish a relationship between my core and dist. routers. Core is running BGP just fine and Dist. is running OSPF without issues.
Joseph W. Doherty Mon, 01/12/2009 - 18:54
Mixing BGP and OSPF on the same router shouldn't normally be an issue. Since your problem is OSPF between core and distribtion, carefully check OSPF configuration on both routers insuring intended interfaces are included within OSPF domain, OSPF attributes match, etc. When doing so wouldn't interrupt production network usage, you might also activate debug for OSPF and insure each router is seeing other's Hellos.
Jesse Hottle Tue, 01/13/2009 - 12:49
I have tried all I can and it doesnt appear that the routers are seeing each others hello messages.
JORGE RODRIGUEZ Thu, 01/15/2009 - 15:40
As Joseph pointed out, configs would help, but definately debuging hello messages should indicate the flaw and why they do not establish neighbor relationship.
post output of "debug ip ospf hello" from either from your Net_core, or Net_dist.
