MPLS PE IOS for 6500?
Answered Question
Jan 12th, 2009
  • Bronze, 100 points or more
I apologize as this is kind of a "Out There" request. I'm setting up my first "service provider" type MPLS network consisting of several 6500s and ASRs. I've been looking around for a while now for a good IOS to load on the 6500s that will support a PE role (with 20-25 CEs on each initially and scale from there).
As I am a bit new to this design selection - does anyone have a recommendation of a good IOS to look at (Sup 720s w/ MSFC 3s)? It would be great if the IOS showed support for FWSMs as there are a few in the mix that need to be used.
Any help would be appreciated. My mind spins a little when looking at several "similar" IOS versions that appear to have differing features.
Jim
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello GP,
I agree we use
s72033-advipservicesk9_wan-mz.122-18.SXF14.bin
with PE role and FWSM blade supported
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
gauravprakash Tue, 01/13/2009 - 01:20
You can try s72033-adventerorisek9_wan-mz.122-18.SXF12a
GP
Correct Answer
Giuseppe Larosa Tue, 01/13/2009 - 03:05
  • Hall of Fame,
    Founding Member
Hello GP,
I agree we use
Hope to help
Giuseppe
jim_berlow Tue, 01/13/2009 - 08:55
Thanks for your help guys (very appreciated). I'll take a close look at them.
Jim
