glen.grant Mon, 01/12/2009 - 17:18
Someone is trying to use snmp on your 6500 , if it doesn't tell you in the logs what address then you might have to use a sniffer . If it tells you then track down the address and ask the the user why his device is attempting an snmp query on that device.
navinder.singh Mon, 01/12/2009 - 17:49
Hi Thanks for the reply the host Ip address showing by the logs is one of my application server. kindly suggest the solution that how can i eradicate this issue
ciscosrini369 Mon, 01/12/2009 - 20:59
look in the server whether i genuinly uses the SNMP, if not stop any SNMP service on that server
--srini
